Indicates that an attempt to send tech support report to a collector failed. collector: Hostname or IP address of a tech support collector port: TCP port number that the collector is listening dataset: Data set configured for the collector sslmode: Whether SSL is enabled or disabled when connecting to the collector reason: Failure reason
The 'show tech-support collector' command can be used to verify configuration of a collector and check status of last report. Make sure that the hostname or IP address of a collector, the TCP port that a collector is listening, and whether SSL is enabled on the TCP port are configured correctly. Once corrected, re-run 'run tech-support report collector' command to send the report again.
Error
Failed to send the %dataset% tech support report to the collector %collector%:%port% with SSL %sslmode% (%reason%)
| Name | Type |
| collector | String |
| port | uInt32 |
| dataset | String |
| sslmode | String |
| reason | String |
